Should be fine. Tricky bit will be finding the right diameter drill to get a good press fit on the oiler, I'd try it out on a non-important bolt first.
I'll try and find and attach a picture I have of an original "Bolt B" when I get home.
Nick Heating the aluminium housing with a hot air gun once relevant fixings have been removed will help if the dynamo is stubborn
24-10-2019, 04:33 PM
(This post was last modified: 24-10-2019, 04:34 PM by Nick Salmon.)
Thanks Dave - it came out without difficulty. Now I am trying to understand why someone would go to the expense and trouble of having the engine rebuilt and then put the dyno in with leads connected to the brush carriers - but two brushes non-existent! No wonder there is no charge...
Thanks Parazine, that would be very helpful.
