Yes - you must loosen A and then remove B.
It can be tight but should rotate back and forth, then out!
Many thanks Ruairidh. How long is bolt B? Can it be removed sufficiently without taking the fan carrier off?
Bolt B is of a similar type to a front camshaft bearing locator, quite short with a plain portion at the end.
Robert Leigh
Phew, relief. Thanks Robert.
A gentle nudge with an oil filter removing strap / tool helps too.. mine is made with a rubber strap so doesn't mark or damage the dynamo
That's interesting, thanks. In the absence of such a thing would it make sense to occasionally remove bolt B and pop a drip or two of oil down the hole?
In practice, that's what I do! Don't go overboard though. I WILL get round to making the oiler one day.
Yes, I do have the oiler on mine. Nick's question referred to a bolt, and my aged memory forgot the real situation.
Robert Leigh
