Astonishing attention to detail
A 4-seat tourer with incredible care taken to ensure that the smallest details are correct. This car has its original armoured cable - softened by a chemical process to make it pliable again. Also, note the tiny seal on the cut-out/fuse box, the correct type of plug and - even rarer - the proper short-type terminal end to the HT leads secured with the right, knurled-edge, screw tops complete with double-spring washers. The rest of the car is not bad, either. The owner insists that the number of twists in the two wires to the horn is also spot on - and who could disagree? Click each picture for a higher resolution copy.
Astonishing attention to detail - by Tony Griffiths - 03-07-2023, 06:22 PM
