Astonishing attention to detail - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Astonishing attention to detail (/showthread.php?tid=8708) |
Astonishing attention to detail - Tony Griffiths - 03-07-2023 A 4-seat tourer with incredible care taken to ensure that the smallest details are correct. This car has its original armoured cable - softened by a chemical process to make it pliable again. Also, note the tiny seal on the cut-out/fuse box, the correct type of plug and - even rarer - the proper short-type terminal end to the HT leads secured with the right, knurled-edge, screw tops complete with double-spring washers. The rest of the car is not bad, either. The owner insists that the number of twists in the two wires to the horn is also spot on - and who could disagree? Click each picture for a higher resolution copy. RE: Astonishing attention to detail - Reckless Rat - 03-07-2023 Shouldn't the fan be painted red? "Very nice, young Harold!" RE: Astonishing attention to detail - Henry Harris - 03-07-2023 I spy a Ruby carburettor! RE: Astonishing attention to detail - Dave Mann - 03-07-2023 So Reckless you remember the story of the dog with red painted tackle. RE: Astonishing attention to detail - Ian Williams - 03-07-2023 Very nicely done, there are a few details that we could pick up on if being pedantic, like the finish on the firewall being glossy, the cut out covers being painted brown, fan etc. However I feel the owner should be applauded for the effort that has been put in so the car presents closely to how it would have done when built. RE: Astonishing attention to detail - Chris Garner - 03-07-2023 I'd be a little twitchy in using original wiring. RE: Astonishing attention to detail - Reckless Rat - 03-07-2023 I have to admit I'm no rivet counter and I agree with Ian that the tourer is wonderfully presented. On my 33 RP the wiring terminal block (the round one) is inside the car, and was there when I acquired it. Is that a model change or just a rebuild error, not that I really can be arsed to change it if it's wrong, I'm just curious. RE: Astonishing attention to detail - David Stepney - 04-07-2023 My round wiring block is on the inside of the car too. The nuts securing it appear to be captive on the outside of the bulkhead, so I presume original. RE: Astonishing attention to detail - Duncan Grimmond - 04-07-2023 Surely there must be a degree of discretionary flexibility? As the cars were hand built Reg might have been left handed and put the turns in the horn wires backwards while Ron did them clockwise? A tolerance in the "crown to sphincter ratio" should also be made... RE: Astonishing attention to detail - Andy Bennett - 04-07-2023 My 33RP round wiring block is also on the inside. It has a sort of indent on the outside so I always assumed it had been changed, but perhaps not. |
