Ruby Starter Pull Cable
k8207418, What is the problem with your cable pull. When I first acquired my Ruby the knob assembly was tight to pull and had to be pushed back in by hand. On removing from the outer I found a bodged attempt to solder a new cable to the shank of the knob. A bit of work with a file soon removed the access solder and it has worked correctly ever since.
John Mason.
Ruby Starter Pull Cable - by k8207418 - 15-10-2022, 12:08 AM
RE: Ruby Starter Pull Cable - by Mike Costigan - 15-10-2022, 08:14 AM
RE: Ruby Starter Pull Cable - by k8207418 - 15-10-2022, 08:26 AM
RE: Ruby Starter Pull Cable - by John Mason - 15-10-2022, 01:42 PM
RE: Ruby Starter Pull Cable - by k8207418 - 15-10-2022, 02:15 PM
RE: Ruby Starter Pull Cable - by Steve Jones - 15-10-2022, 02:19 PM
RE: Ruby Starter Pull Cable - by Howard Wright - 15-10-2022, 03:34 PM
RE: Ruby Starter Pull Cable - by k8207418 - 15-10-2022, 03:57 PM
RE: Ruby Starter Pull Cable - by Michael D - 15-10-2022, 04:57 PM
