Rear hub tapers
Many thanks.
Loctite 660 on order.
I made up a dummy bearing which was an easy slide fit in the hub and on the axle casing. I could then slide the halfshaft and hub in and out to check clearance.
I reckon that if the taper comes to the end of the hub there would still be some clearance, unless someone had already machined the halfshaft gears for more clearance!!!
Adrian.
Rear hub tapers - by Adrian Payne - 19-08-2022, 09:25 PM
RE: Rear hub tapers - by leaf200 - 20-08-2022, 06:19 AM
RE: Rear hub tapers - by Howard Wright - 20-08-2022, 07:30 AM
RE: Rear hub tapers - by Adrian Payne - 21-08-2022, 07:59 PM
