10-08-2022, 05:00 PM
The tappet spanners are stamped out of flat then hardened and tempered
1/4" and 5/16" Spanner Size.
They do not need to be very stong as you do not need much force to correctly set and tighten the tappets the taper nut being split and working as wedge in the tappet will stop things from moving.
Over tightening can cause the tappet block to split and jam in the guide.
