Starter Motor M35a
If you take the band off make sure you remove the switch as well.
The reason is that the band has a half moon cut out which fits around the copper contact on the starter motor.
If the band is fitted incorrectly it can cause a dead short when you operate the starter switch.
Refit the band making sure it is not touching the copper contact then re fit the switch.
Starter Motor M35a - by k8207418 - 06-08-2022, 01:01 PM
RE: Starter Motor M35a - by David Stepney - 06-08-2022, 05:24 PM
RE: Starter Motor M35a - by k8207418 - 06-08-2022, 06:47 PM
RE: Starter Motor M35a - by dickie65 - 08-08-2022, 06:29 PM
RE: Starter Motor M35a - by k8207418 - 08-08-2022, 06:33 PM
