  • 1 Vote(s) - 1 Average
Rear spring u bolts
Assuming that you've got the same access slot over the chassis for the other side, it should be a simple job to drop the new 'U' bolts in through the holes and then bolt them up from underneath. I would check the tightness of the spring locating bolts while you're at it (they are the ones just forward of the U bolts) and which are also tightened from underneath.
Rear spring u bolts - by Peter Sweeney - 13-06-2022, 03:38 PM
RE: Rear spring u bolts - by Reckless Rat - 13-06-2022, 04:10 PM
RE: Rear spring u bolts - by Peter Sweeney - 14-06-2022, 11:14 AM
RE: Rear spring u bolts - by Murdock - 15-06-2022, 12:18 PM
RE: Rear spring u bolts - by Martin Prior - 16-06-2022, 12:45 PM
RE: Rear spring u bolts - by Murdock - 17-06-2022, 11:17 AM
RE: Rear spring u bolts - by Ian Dunford - 17-06-2022, 09:17 PM
