16-04-2022, 07:10 PM
(This post was last modified: 16-04-2022, 07:19 PM by Terrytuned.
Edit Reason: update
Don't use them get an inter bush from A7 suppliers much better, those bearings can damage the end of the mainshaft and the bore of the 1st motion shaft. Or if you mean the bearing at the front of the nose piece use a good used one they should not be hard to source. Terry.
