cu carb
(29-03-2022, 06:54 AM)Ian Williams Wrote: You will need to provide a lot more information to obtain and answer which is relevant to your situation, if you have a standard unmodified engine the carb you have is too big and will never provide optimum performance.
If your engine is moderately tuned you could start with a no.6 needle and blue spring. It may be on the rich side but it’s what I use and seems to give a good performance.
cu carb - by bruce legg - 29-03-2022, 03:09 AM
RE: cu carb - by Ian Williams - 29-03-2022, 06:54 AM
RE: cu carb - by Charles Levien - 29-03-2022, 08:08 AM
RE: cu carb - by Tony Press - 29-03-2022, 09:43 PM
