06-03-2018, 07:27 PM
(06-03-2018, 07:03 PM)John Cornforth Wrote:(06-03-2018, 06:20 PM)David.H Wrote: Well the bowl is off ...lots of sediment & various holes bunged up! jets cleaned out, I'll note the numbers!
I haven't yet removed the emulsion block (?) with it's seven cheese head screws.
Not much in the way of gaskets yet (except needle valve & banjos).
I wonder if I dare put it in the ultrasonic cleaner (for jewellery!)
Hi David
You might like to consider what is going to happen to any loosened sediment from ultrasonic cleaning - to my way of thinking there is a risk that it could block up one of the fine passages which are difficult to access. Maybe using a fine nozzle on an air line afterwards would clear things through ?
Correct!
D
