Dizzy gear pin
Peter, not sure I should raise my head up over the parapet here but.......
Same situation, I need to change the bottom disty shaft, the one with the helical gears on my DJ4A.
Lucas says use a 1/8 “ pin. I did not have one and the UK is a couple of weeks away from me in NZ.
So I rustled about in my nail collection and found a galvanised nail slightly over size but a bit of coarse emery cloth reduced it to fit.
Firm fit and then peen or centre punch each end.
I did find that the hole going through the disty part didn’t line up with the hole in the new bottom shaft.
Turned it around 180 and all was good.
Not a lot of precision accuracy back in the day.
Gary
Auckland0
Dizzy gear pin - by Peter Arnold - 25-05-2021, 03:32 AM
RE: Dizzy gear pin - by Howard Wright - 25-05-2021, 08:01 AM
RE: Dizzy gear pin - by John Cornforth - 25-05-2021, 08:15 AM
RE: Dizzy gear pin - by Terrytuned - 25-05-2021, 10:42 AM
RE: Dizzy gear pin - by Ian McGowan - 25-05-2021, 01:24 PM
RE: Dizzy gear pin - by Nick Turley - 25-05-2021, 04:00 PM
RE: Dizzy gear pin - by Ruairidh Dunford - 25-05-2021, 04:46 PM
RE: Dizzy gear pin - by Peter Arnold - 28-05-2021, 06:41 AM
RE: Dizzy gear pin - by GaryCullen - 28-05-2021, 08:18 AM
RE: Dizzy gear pin - by Bob Culver - 28-05-2021, 08:48 AM
RE: Dizzy gear pin - by Jeff Taylor - 28-05-2021, 12:20 PM
