Trafficator switch/inner control column of steering column
The steering column Top Felt Bush is available from the Seven Workshop - part FA0673 @ £2.04p. As Jack points out the flat piece of shaped felt is fitted in a spiral.
https://www.theaustinsevenworkshop.com/p...-bush-9393
RE: Trafficator switch/inner control column of steering column - by Jeff Taylor - 29-01-2018, 12:47 PM
