Trafficator switch/inner control column of steering column - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Trafficator switch/inner control column of steering column (/showthread.php?tid=754) |
Trafficator switch/inner control column of steering column - Christopher - 28-01-2018 Hello Austin Seven Friends This is my first post to this forum. I hope somebody will be able to help! I replaced the steering wheel of my Ruby ARR with a recoated one. The inner part of the original (old) steering wheel and the new steering wheel does not look exactly the same (see attached photos) When I reinserted the trafficator switch/inner control column through the new steering wheel into the steering column I could not achieve the gap anymore between the trafficator switch and the steering wheel, thus the trafficator switch moves with the steering wheel. First, I thought that the reason was the new steering wheel which does not look exactly the same inside as the old steering wheel. Then I inserted the inner control column into the old steering wheel outside of the car but could not see out any difference, so the solution must be somewhere between inner control column and the steering column, but where? Does anybody know how to achieve the gap between the trafficator switch and the steering wheel so that the trafficator switch does not move with the steering wheel? The spare parts booklet shows felt bushes for inner column, top and lower. Are these the solution? If yes, I do not have them and also do not know where to get them... I am most glad to receive any feedback to solve this problem and enabling me to reassemble by Ruby ARR. Thanks a lot Christopher RE: Trafficator switch/inner control column of steering column - Derek Sheldon - 28-01-2018 (28-01-2018, 01:56 PM)Christopher Wrote: Hello Austin Seven FriendsPull the switch assembly back out to achieve the clearance required and tighten the clamp at the bottom of the steering column RE: Trafficator switch/inner control column of steering column - Oxford Jack - 28-01-2018 (28-01-2018, 01:56 PM)Christopher Wrote: Hello Austin Seven Friends RE: Trafficator switch/inner control column of steering column - John Cornforth - 28-01-2018 I put up with non-functioning cancel function on the trafficators for years. Later I discovered that the steering wheel had been fitted 180 degrees out by a previous owner. Refitting it properly made the cancelling work, the cast boss inside the wheel then engaging with the trafficator mechanism. The steering wheel spokes should be in an upside-down "Y" pattern when the front wheels are pointing straight ahead, if that makes sense. A side effect of this is that the vertical spoke obscures the speedo when you are doing 30 MPH unless you move your head and body slightly to one side. RE: Trafficator switch/inner control column of steering column - Tony Press - 28-01-2018 (28-01-2018, 06:39 PM)John Cornforth Wrote: I put up with non-functioning cancel function on the trafficators for years. Later I discovered that the steering wheel had been fitted 180 degrees out by a previous owner. Refitting it properly made the cancelling work, the cast boss inside the wheel then engaging with the trafficator mechanism. Isn't the steel bit replaced by the diecast bump ? Tony. RE: Trafficator switch/inner control column of steering column - Jeff Taylor - 29-01-2018 The steering column Top Felt Bush is available from the Seven Workshop - part FA0673 @ £2.04p. As Jack points out the flat piece of shaped felt is fitted in a spiral. https://www.theaustinsevenworkshop.com/products/fa0673-steering-column-top-felt-bush-9393 |
