Trafficator switch/inner control column of steering column
I put up with non-functioning cancel function on the trafficators for years.  Later I discovered that the steering wheel had been fitted 180 degrees out by a previous owner.  Refitting it properly made the cancelling work, the cast boss inside the wheel then engaging with the trafficator mechanism.
The steering wheel spokes should be in an upside-down "Y" pattern when the front wheels are pointing straight ahead, if that makes sense.  A side effect of this is that the vertical spoke obscures the speedo when you are doing 30 MPH unless you move your head and body slightly to one side.
RE: Trafficator switch/inner control column of steering column - by John Cornforth - 28-01-2018, 06:39 PM
