Steering side tube aka drag link greasing
Hi All
I’m about to fabricate a new steering side tube (BM99) or drag link for my special to ensure the drop arm doesn’t go “over centre”.
Whilst doing this I want to add a bolt adjuster to the end of the caps (BM101) AND if possible a grease nipple.  I understand that later Rubys had a grease nipple fitted but I can’t find a picture or diagram of where the nipple was located.
My idea is to drill the end of the cap, braze a 3/8” nut onto the end. A 3/8” bolt, drilled and tapped to take a 1/4” grease nipple acts as the adjuster.
My question is will sufficient grease find its way past the thrust block to lubricate the ball?  I don’t fancy trying to drill a grease hole through the hardened thrust block!
Steering side tube aka drag link greasing - by Howard Wright - 06-05-2020, 08:40 AM
