Damaged or Unservicable parts
(02-05-2020, 09:53 PM)Ian Williams Wrote: You have a stock of high quality steel and aluminium that can be turned into something else, all you need is imagination, this is the example I referred to entirely made from scrap box materials.
This is very interesting, as seeing it, one can start to see the possibility for doing things yourself. But a lot of us don't have lathes or the ability to weld. I'm starting to investigate what can be done with a plumbers propane torch -  could that aluminium weld be done with that? What are the functions at the left hand end and which are the recycled bits which contribute to them please? Is that a spring shackle half way down the gearstick?
Damaged or Unservicable parts - by Winston Teague - 01-05-2020, 06:57 PM
RE: Damaged or Unservicable parts - by Tony Betts - 01-05-2020, 09:36 PM
RE: Damaged or Unservicable parts - by Steve kay - 02-05-2020, 09:51 AM
RE: Damaged or Unservicable parts - by Chris KC - 02-05-2020, 01:37 PM
RE: Damaged or Unservicable parts - by GK5268 - 02-05-2020, 02:23 PM
RE: Damaged or Unservicable parts - by JonE - 04-05-2020, 05:28 PM
RE: Damaged or Unservicable parts - by Joss - 04-05-2020, 11:39 PM
