Damaged or Unservicable parts - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Damaged or Unservicable parts (/showthread.php?tid=4292) Pages:
1
2
Damaged or Unservicable parts - Winston Teague - 01-05-2020 Hi All, Patrick (son & heir) and I have spent the day sorting the A7 boxes in the shed. All of them. This is to try and cut down my buying bits for his car, that we already own, however deeply buried they are! This has generated a significant pile of original A7 bits, mostly pre 1930, that are damaged, worn, cracked or all of these! Broken or 'spun' halfshafts, chipped or toothless crown wheeels, broken castings inc. mag timing case and coil dynamo mounting, chipped timing gears, a camshaft with chipped oil pump drive teeth etc. I suspect this lot all needs chucking away, but can anyone think of a use, sculpture? etc It is available free of charge to anyone who wants all or some of it, and if you make a good enough case i will even pack and ship it at my expense, but you have to have a good idea! Lock down challenge. W RE: Damaged or Unservicable parts - Tony Betts - 01-05-2020 hi winston, now you know why it takes me a week to sort the parts you ask for in GOOD CONDITION. there is so much scrap out there. if someone wants to make a really large sculpture, i have a pill of scrap 7 parts whaiting to go to the tip. but cant under lockdown. hope someone comes up with something fun though, tony. RE: Damaged or Unservicable parts - Ivor Hawkins - 02-05-2020 How about building an engine from all those parts as the perfect compliment to one of the “waterski” specials! RE: Damaged or Unservicable parts - Duncan Grimmond - 02-05-2020 (02-05-2020, 09:10 AM)Ivor Hawkins Wrote: How about building an engine from all those parts as the perfect compliment to one of the “waterski” specials! Well spotted, a match made in heaven! RE: Damaged or Unservicable parts - Steve kay - 02-05-2020 Indeed, with lockdown making the River Teme inacessible to the wealthy water sport classes, there are probably numbers of disused waterskis lying about as well. At other times no doubt arrangements could be made in the back bar of the Vaults. RE: Damaged or Unservicable parts - Ian Williams - 02-05-2020 Or you could build a remote gear change like the one Joss recently posted here, all from scrap bin parts. RE: Damaged or Unservicable parts - Winston Teague - 02-05-2020 Ive just added a lengthened carden propshaft and a short stump of same...... I'm a bit lost on the waterski references... It would be a very heavy remote gear linkage! RE: Damaged or Unservicable parts - Chris KC - 02-05-2020 Amazing though how after you throw something away you find a way in which it might have been useful. RE: Damaged or Unservicable parts - GK5268 - 02-05-2020 waterski refers to an eBayer who is described by some people as selling some crappy half-finished special at what they think is a vastly inflated price, caveat emptor, as always. if something is too good to be true then it usually is! so, with your broken & busted parts, making something that could fit in with this eBayer... RE: Damaged or Unservicable parts - Phil Kingdom - 02-05-2020 It would be a bit of fun to make up a cutaway engine using all damaged parts, ideal for a man cave and probably sellable on E bay! |
