rev counter drive
I can still do these but require the dynamo end and distributor shaft to do it.The dynamo end needs to be drilled and faced in the lathe to do a good job.The drive cable is likely to fail quickly if not.
I can make the drive the same as the gearbox output. Pm me if so.
Is your rev counter 2:1,will it run both ways ?
rev counter drive - by mopetta - 12-04-2020, 06:17 PM
RE: rev counter drive - by Chris KC - 12-04-2020, 06:36 PM
RE: rev counter drive - by Howard Wright - 12-04-2020, 06:53 PM
RE: rev counter drive - by Erich - 12-04-2020, 07:22 PM
RE: rev counter drive - by Lowespeed - 13-04-2020, 05:08 PM
RE: rev counter drive - by Lowespeed - 14-04-2020, 05:23 PM
RE: rev counter drive - by Gem4373 - 16-04-2020, 12:47 PM
RE: rev counter drive - by Austin in the Shed - 16-04-2020, 01:43 PM
