Front shackles
I replaced my front axle shackles and bushes recently. I went for a smooth push fit of the lightly oiled pin in the bush that I could press in with my little finger. A good tip I was given was to soak your reamer in paraffin if you need to take a little more material out of the bush. If the new bush is loose in the spring eye a layer of solder works well to fill the gap.
Front shackles - by mhacche - 12-02-2020, 08:10 PM
RE: Front shackles - by Bob Kneale - 12-02-2020, 09:15 PM
RE: Front shackles - by mhacche - 12-02-2020, 11:12 PM
RE: Front shackles - by Bela - 10-04-2020, 06:49 PM
RE: Front shackles - by Andy Bennett - 10-04-2020, 07:21 PM
RE: Front shackles - by Bela - 10-04-2020, 08:03 PM
RE: Front shackles - by Colin Wilks - 10-04-2020, 09:54 PM
