Front shackles - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Front shackles (/showthread.php?tid=3893) |
Front shackles - mhacche - 12-02-2020 What is the diameter of the front shackles bush and pin please? RE: Front shackles - Bob Kneale - 12-02-2020 Hi there. The bush (and therefore pin diameter) is 7/16". Fit the bush in the spring eye and ream to the final diameter in place. Cheers Bob RE: Front shackles - mhacche - 12-02-2020 Thank you Bob, I had a feeling it was 7/16 but it’s good to ask?. I have reamers ? RE: Front shackles - Bela - 10-04-2020 Hello I never had reamed such a bush. What is a appropriate play between bush and bolt? RE: Front shackles - Andy Bennett - 10-04-2020 I reamed mine to move it from what would have been a tight/slight press fit to a nice smooth fit, perhaps a couple of thou, so just enough gap for smooth lubrication? Andy B RE: Front shackles - Bela - 10-04-2020 Of course there must be a gap for lubrication. Are there concrete hints in any workshop manual? Same problem will occur when i will change the bush and the brake cam. RE: Front shackles - Colin Wilks - 10-04-2020 I replaced my front axle shackles and bushes recently. I went for a smooth push fit of the lightly oiled pin in the bush that I could press in with my little finger. A good tip I was given was to soak your reamer in paraffin if you need to take a little more material out of the bush. If the new bush is loose in the spring eye a layer of solder works well to fill the gap. |
