PCD Wheel studs
It's usually easier to measure the spacing from the side of the stud than trying to guess the centre. That is left side to left side or right side to right side which will be the same as centre to centre.
I make the stud spacing 4" measuring the holes on a hub outer
PCD Wheel studs - by Duncan Grimmond - 29-11-2017, 02:03 PM
RE: PCD Wheel studs - by Peter Clayton - 29-11-2017, 02:44 PM
RE: PCD Wheel studs - by Duncan Grimmond - 29-11-2017, 03:46 PM
RE: PCD Wheel studs - by AustinWood - 29-11-2017, 05:24 PM
RE: PCD Wheel studs - by Marcus Ling - 29-11-2017, 09:23 PM
RE: PCD Wheel studs - by Paul N-M - 30-11-2017, 04:34 PM
RE: PCD Wheel studs - by Duncan Grimmond - 30-11-2017, 06:55 PM
