PCD Wheel studs - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: PCD Wheel studs (/showthread.php?tid=506) |
PCD Wheel studs - Duncan Grimmond - 29-11-2017 Could someone post the PCD for wheel studs please? Or, tell me where to find it? RE: PCD Wheel studs - Peter Clayton - 29-11-2017 www.ptsintl.com/pdfs/Multihead%20Centinel/PitchCircle.pdf How good are your maths.? RE: PCD Wheel studs - Duncan Grimmond - 29-11-2017 Thanks for that, I wanted to check my calculation against the reality of a factory drawing. It's really difficult finding the exact centre point of the stud...or am I disappearing up my own fundament? RE: PCD Wheel studs - AustinWood - 29-11-2017 It's usually easier to measure the spacing from the side of the stud than trying to guess the centre. That is left side to left side or right side to right side which will be the same as centre to centre. I make the stud spacing 4" measuring the holes on a hub outer RE: PCD Wheel studs - Marcus Ling - 29-11-2017 (29-11-2017, 02:03 PM)Duncan Grimmond Wrote: Could someone post the PCD for wheel studs please? Hi Duncan, I believe the PCD is 4 and 5/8, that what it is on the hub holding tool I make here. Cheers Marcus RE: PCD Wheel studs - Paul N-M - 30-11-2017 (29-11-2017, 02:03 PM)Duncan Grimmond Wrote: Could someone post the PCD for wheel studs please? 4 and 5/8" is correct. Paul N-M RE: PCD Wheel studs - Duncan Grimmond - 30-11-2017 (30-11-2017, 04:34 PM)Paul N-M Wrote:(29-11-2017, 02:03 PM)Duncan Grimmond Wrote: Could someone post the PCD for wheel studs please? Many thanks. |
