oil pressure gauge feed pipe - size?
It's a good idea to form a simple loop in the pipe to accommodate vibration / thermal expansion / engine movement, you don't want the pipe under strain. It's quite easily worked if you anneal it first (heat till it glows red, quench with cold water).
oil pressure gauge feed pipe - size? - by JonE - 21-06-2019, 08:50 PM
RE: oil pressure gauge feed pipe - size? - by Chris KC - 21-06-2019, 10:14 PM
