oil pressure gauge feed pipe - size? - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: oil pressure gauge feed pipe - size? (/showthread.php?tid=2980) |
oil pressure gauge feed pipe - size? - JonE - 21-06-2019 I noticed this is very thin on my car. More like 4mm copper rather than 6mm diameter or so I've seen elsewhere. Is it adviseable to have wider section for potential blockages, or am I worrying unduly? RE: oil pressure gauge feed pipe - size? - Greig Smith - 21-06-2019 4mm is fine, it only has to register pressure, not provide flow, so no need to go to bigger diameter tube Mine are all 4mm and the oil pressure gauges work just fine Aye Greig RE: oil pressure gauge feed pipe - size? - JonE - 21-06-2019 excellent! And presumably there is no point have massive spirals of copper pipe - just the quickest route there? RE: oil pressure gauge feed pipe - size? - Chris KC - 21-06-2019 It's a good idea to form a simple loop in the pipe to accommodate vibration / thermal expansion / engine movement, you don't want the pipe under strain. It's quite easily worked if you anneal it first (heat till it glows red, quench with cold water). |
