Ignition points
Tiger
the Bosch distributor is quite visually different in that it doesn't have the flattened side bit to the distributor cap. Probably not describing very well but you can see the difference in these ebay items. first is bosch and second in an electronic version of the A7 distributor but shows the flattened bit present on the original:
https://www.ebay.co.uk/itm/Austin-7-Seve...SwWFFa7J5c
https://www.ebay.co.uk/itm/Powerspark-Ne...SwKcZa0MSz
if you have Bosch then you just need to look for spares for Bosch 009. Yu can buy from Austin Seven Reproduction Parts or any VW supplier. I bought a replacement cap for £4:95 couple of weeks ago and some points from a VW supplier at the Practical Classics Show.
Andy
Ignition points - by Tiger - 03-05-2019, 06:11 PM
RE: Ignition points - by Andy Bennett - 03-05-2019, 06:43 PM
RE: Ignition points - by Mark R - 03-05-2019, 06:44 PM
RE: Ignition points - by Tiger - 03-05-2019, 07:52 PM
RE: Ignition points - by Tiger - 03-05-2019, 10:07 PM
RE: Ignition points - by Chris KC - 03-05-2019, 10:28 PM
RE: Ignition points - by Tony Press - 03-05-2019, 10:36 PM
RE: Ignition points - by Tiger - 03-05-2019, 11:00 PM
RE: Ignition points - by Davemayle - 03-05-2019, 11:17 PM
RE: Ignition points - by Bob Culver - 03-05-2019, 11:44 PM
RE: Ignition points - by Ian Williams - 04-05-2019, 12:25 AM
RE: Ignition points - by Tiger - 04-05-2019, 05:21 AM
RE: Ignition points - by John Mason - 05-05-2019, 05:08 PM
RE: Ignition points - by Robert Foreman - 06-05-2019, 08:02 AM
RE: Ignition points - by David.H - 06-05-2019, 09:47 AM
