Wheeling machines
I have an inexpensive Asian made English wheel $600, which is about 300 pounds, my friend Joss has a big cast Edwards machine. The comparison between the two in use is interesting, certainly mine is far less rigid than the Edwards so needs a slightly adapted technique but you can still do some good work. Mine also came with a wide range of lower anvils from flat to quite tight radius which is useful, add a rubber band on the top wheel and you can form single curvature panels which is also very useful . You just have to accept that you may need to make a few improvements to the cheap units, the yoke for the bottom wheel had a bit more movement than I would have liked which affected accuracy of your tracking, but that was easily shimmed to fix. Buy one and have a play!
Wheeling machines - by DavidL - 24-04-2019, 11:03 PM
RE: Wheeling machines - by Duncan Grimmond - 24-04-2019, 11:20 PM
RE: Wheeling machines - by DavidL - 24-04-2019, 11:48 PM
RE: Wheeling machines - by Ian Williams - 25-04-2019, 12:48 AM
RE: Wheeling machines - by DavidL - 25-04-2019, 12:01 PM
RE: Wheeling machines - by Ian Williams - 26-04-2019, 04:13 AM
RE: Wheeling machines - by Martin Prior - 26-04-2019, 07:15 AM
RE: Wheeling machines - by AllAlloyCup - 26-04-2019, 08:58 AM
RE: Wheeling machines - by Martin Prior - 26-04-2019, 09:23 AM
RE: Wheeling machines - by DavidL - 26-04-2019, 11:17 AM
RE: Wheeling machines - by Mark Atkinson - 26-04-2019, 08:02 PM
RE: Wheeling machines - by Ian Williams - 26-04-2019, 08:40 PM
RE: Wheeling machines - by DavidL - 26-04-2019, 11:43 PM
RE: Wheeling machines - by Martin Prior - 27-04-2019, 08:52 AM
RE: Wheeling machines - by DavidL - 27-04-2019, 04:34 PM
RE: Wheeling machines - by Duncan Grimmond - 27-04-2019, 05:35 PM
RE: Wheeling machines - by Ian Williams - 27-04-2019, 09:40 PM
RE: Wheeling machines - by Martin Prior - 28-04-2019, 10:02 AM
RE: Wheeling machines - by Ian Williams - 28-04-2019, 08:18 PM
RE: Wheeling machines - by Duncan Grimmond - 28-04-2019, 10:59 PM
RE: Wheeling machines - by Charles P - 28-04-2019, 11:22 PM
RE: Wheeling machines - by Duncan Grimmond - 04-05-2019, 06:28 PM
