Propshaft fitting
I have only ever seen the splined sliding section fitted to the gearbox on all the cars old and modern that I have ever played with.
Another point that pops up is the correct alignment of the UJs, again every prop shaft I have seen is aligned with the UJs at 90 degrees to each other,for good mechanical reasons, as explained here, http://www.austin7.org/Technical%20Artic...ft%20Howl/   I have two spare Ruby props that are not in alignment and looking at Holty's picture that one is not either, I had just presumed that the props I had were wrongly assembled,but now having seen three props the same i am starting to wonder how many out of aligned props are out there!
Propshaft fitting - by NickB - 11-10-2017, 10:01 AM
RE: Propshaft fitting - by Reckless Rat - 11-10-2017, 10:52 AM
RE: Propshaft fitting - by Ruairidh Dunford - 11-10-2017, 10:54 AM
RE: Propshaft fitting - by Hedd_Jones - 11-10-2017, 01:14 PM
RE: Propshaft fitting - by NickB - 11-10-2017, 01:55 PM
RE: Propshaft fitting - by NickB - 14-10-2017, 01:31 PM
RE: Propshaft fitting - by Holty - 14-10-2017, 03:28 PM
RE: Propshaft fitting - by "Slack Alice" Simon - 14-10-2017, 02:14 PM
RE: Propshaft fitting - by NickB - 14-10-2017, 03:16 PM
RE: Propshaft fitting - by John Cornforth - 14-10-2017, 04:45 PM
RE: Propshaft fitting - by Phil Kingdom - 14-10-2017, 08:46 PM
RE: Propshaft fitting - by NickB - 14-10-2017, 09:37 PM
RE: Propshaft fitting - by Zetomagneto - 15-10-2017, 02:41 AM
RE: Propshaft fitting - by Steve Bryant - 15-10-2017, 02:57 PM
