Oil Pump
Hi Folks,
Thanks for the response,
I will have to track Paul Bonewell down.
The Nippy Crankcase is going to have a Hadley Crank and Rods installed.
My current Mongrel engine has a Pigsty Oil Pump Conversion and an Allen Crank, this engine is staying in the car till the Nippy Engine is built.
Entered for VSCC Wiscombe in May
I want the Nippy Crankcase / Engine to be more original in appearance.
I intend to use the original oil feeds, uprate the pressure relief valve and restrict oil flow to the Camshaft bearings.
I do not want the oil to come out of the pressure gauge port and into a filter/ remote pressure relief on the head then a load of armoured pipes running about.
I already have available a Double pump conversion from the 50's / 60's but would like to use a more modern solution.
Oil Pump - by dickie65 - 02-03-2019, 06:41 PM
RE: Oil Pump - by Chris KC - 02-03-2019, 07:10 PM
RE: Oil Pump - by Colin Wilks - 02-03-2019, 07:15 PM
RE: Oil Pump - by Charles P - 02-03-2019, 09:44 PM
RE: Oil Pump - by Alan - 02-03-2019, 10:54 PM
RE: Oil Pump - by dickie65 - 02-03-2019, 11:41 PM
RE: Oil Pump - by Chris KC - 02-03-2019, 11:50 PM
RE: Oil Pump - by Charles P - 03-03-2019, 12:18 AM
RE: Oil Pump - by Chris KC - 03-03-2019, 09:01 AM
