Oil Pump - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Oil Pump (/showthread.php?tid=2474) |
Oil Pump - dickie65 - 02-03-2019 Hi, I am looking for a High Flow High Pressure oil pump to use the standard fitting and feeds ( 1934 Crankcase ) can anyone direct me to a Supplier. Cheers Dickie RE: Oil Pump - Chris KC - 02-03-2019 Tony Betts or Tony Leslie sell over-bored A7 oil pumps from time to time, one of them should be able to sort you out. http://www.7ca.co.uk/ HOLMESDALE SEVENS (Tony Leslie) holmesdale7@gmail.com RE: Oil Pump - Colin Wilks - 02-03-2019 I'm fairly sure John Barlow had some at the back end of last year. Colin RE: Oil Pump - Charles P - 02-03-2019 Paul. Bonewell made the gear type that is a straight swap for the original Charles RE: Oil Pump - Alan - 02-03-2019 Depends what you want it for. On a splash fed engine an overbored pump will be more than adequate. For a pressure fed engine I’d use one of Paul Bonewell’s. RE: Oil Pump - dickie65 - 02-03-2019 Hi Folks, Thanks for the response, I will have to track Paul Bonewell down. The Nippy Crankcase is going to have a Hadley Crank and Rods installed. My current Mongrel engine has a Pigsty Oil Pump Conversion and an Allen Crank, this engine is staying in the car till the Nippy Engine is built. Entered for VSCC Wiscombe in May I want the Nippy Crankcase / Engine to be more original in appearance. I intend to use the original oil feeds, uprate the pressure relief valve and restrict oil flow to the Camshaft bearings. I do not want the oil to come out of the pressure gauge port and into a filter/ remote pressure relief on the head then a load of armoured pipes running about. I already have available a Double pump conversion from the 50's / 60's but would like to use a more modern solution. RE: Oil Pump - Chris KC - 02-03-2019 For what it's worth I've run a pressure fed 3-bearing crank on the road since the 1980's with an over-bored A7 pump. Runs at 35 - 50 psi without issues. Can't comment on the Hadley though. RE: Oil Pump - Charles P - 03-03-2019 (02-03-2019, 11:41 PM)dickie65 Wrote: Hi Folks, I suggest that you get in contact with Damian GT, who posts here and has a tidy Supersports replica. His remote filter is really nicely hidden leaving a clean engine bay. Charles RE: Oil Pump - Chris KC - 03-03-2019 I'd be interested to hear about that. Damian? |
