Front cover
The nose of the casting on my engine has suffered over the years & quite a large chunk at the end (about 5-8 o'clock & an inch) is no longer there! Clearly the starting handle has been rattling up & down. Unsurprisingly there is significant wear on the starting handle shaft as well.
I am not minded to find a replacement cover & think this must be a well known problem...is there a "fix"? I am thinking of fitting a bush/sleeve over the handle shaft & fitting it into the nose of the cover. Maybe made from a hard plastic polybush?. The car starts well on the motor, so I don't anticipate lots of winding in future. I am more concerned to stop the handle shaft rattling about.
The bush would be quite thin as the gap from shaft o/d to cover i/d is "only!" about .030" (variable!). I recall seeing "steel tubes" from somewhere that might be to solve this one, but cannot find them...do they work? I don't want to have to machine the components unless I have to. My plan is a to just find a "fix" at this stage.
Front cover - by David.H - 21-08-2018, 08:34 PM
RE: Front cover - by Douglas Alderson - 21-08-2018, 10:09 PM
RE: Front cover - by David.H - 22-08-2018, 10:34 AM
RE: Front cover - by Austin in the Shed - 22-08-2018, 12:58 PM
RE: Front cover - by Steve Jones - 22-08-2018, 01:14 PM
RE: Front cover - by Reckless Rat - 22-08-2018, 01:28 PM
RE: Front cover - by David.H - 22-08-2018, 02:47 PM
RE: Front cover - by Steve Jones - 22-08-2018, 02:55 PM
RE: Front cover - by cardiffrob - 22-08-2018, 03:21 PM
RE: Front cover - by jansens - 22-08-2018, 09:28 PM
RE: Front cover - by cardiffrob - 23-08-2018, 07:32 AM
RE: Front cover - by Chris KC - 23-08-2018, 04:49 PM
RE: Front cover - by Bob Culver - 23-08-2018, 07:56 AM
RE: Front cover - by Dave Mann - 23-08-2018, 10:05 AM
RE: Front cover - by jansens - 23-08-2018, 06:37 PM
RE: Front cover - by Reckless Rat - 23-08-2018, 07:02 PM
