08-08-2018, 03:03 PM
(08-08-2018, 08:49 AM)Chris KC Wrote:(08-08-2018, 08:46 AM)AustinWood Wrote: The large brass washers are 'separator discs'. These were fitted between the mounting bracket and the friction disc but only on the back shock absorbers not the front.
I don't know why.
Must say that has always baffled me!
I thought the brass disc on the rear shock absorbers were to prevent wear on the brackets that are riveted to the chassis. The front bracket is bolted on and could be replaced if worn.
