Front shock on Ulster Rep - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Front shock on Ulster Rep (/showthread.php?tid=1554) |
Front shock on Ulster Rep - Erich - 08-08-2018 Hi All, I decided today that I would paint the front shock on my recently acquired Ulster Rep. Easy, I thought, a couple of bolts and I could paint. What I found was not as was described in the Woodrow book. First, the OS center twin arm had its mounting holes for the bushed end, drilled to 1/2 inch. The NS arms were drilled to 5/8. The latter had been bushed while the former was not. Both fixing bolts were a sloppy fit. Further, I found two brass washers, the size of the friction discs, on either side of the mounting bracket. It would seem that the brass washers would allow easier movement, which would seem to be contradictory to what the shock and the friction discs are supposed to do. Or am I missing some mystical go fast theory? Also, some fiber washers were doubled and others were not there. But a total of eight, just not in the right places. Did Mickey Mouse build this? Erich in Seattle RE: Front shock on Ulster Rep - David.H - 08-08-2018 (08-08-2018, 03:58 AM)Erich Wrote: Hi All,Almost certainly, Erich. My AG which came via California was the one he cut his teeth on! He didn't appear to learn anything though when he went on to work on yours in Europe! RE: Front shock on Ulster Rep - AustinWood - 08-08-2018 The large brass washers are 'separator discs'. These were fitted between the mounting bracket and the friction disc but only on the back shock absorbers not the front. I don't know why. RE: Front shock on Ulster Rep - Chris KC - 08-08-2018 (08-08-2018, 08:46 AM)AustinWood Wrote: The large brass washers are 'separator discs'. These were fitted between the mounting bracket and the friction disc but only on the back shock absorbers not the front. Must say that has always baffled me! RE: Front shock on Ulster Rep - Lowespeed - 08-08-2018 (08-08-2018, 08:49 AM)Chris KC Wrote:(08-08-2018, 08:46 AM)AustinWood Wrote: The large brass washers are 'separator discs'. These were fitted between the mounting bracket and the friction disc but only on the back shock absorbers not the front. I thought the brass disc on the rear shock absorbers were to prevent wear on the brackets that are riveted to the chassis. The front bracket is bolted on and could be replaced if worn. |
