Reducing camber of rear springs
(11-07-2018, 08:52 AM)Charles Levien Wrote:
(09-07-2018, 11:12 AM)Tom Coates Wrote:  I would like to lower the back of my GE Cup by a few inches as it sits a bit high at the moment and I think this will improve the appearance and handling. Doing this would reduce the available suspension travel but I’m not planning to do any trials so I think I can live with that.
The question is whether to have some early type springs made up with reduced camber (say 3”), or just to use Ruby springs which I think have a 2½” camber as standard.
I imagine Ruby springs would make the suspension quite stiff which might be good if there is limited travel. Does anyone have experience of using the later springs on a relatively light early car? Will they fit into the ends of the chassis rails without modification? Are there any other issues watch out for (like the axle oil pouring out of the front of the torque tube due to the change in angle?)...
I found using Nippy springs on my 1937 Opal gave the right clearance and excellent ride. If memory serves me right these have a 2.5 inch camber ( think standard Ruby is more) and fewer leaves than Ruby.
Charles
Thanks I'll look into that.
Reducing camber of rear springs - by Tom Coates - 09-07-2018, 11:12 AM
RE: Reducing camber of rear springs - by Chris KC - 09-07-2018, 02:26 PM
RE: Reducing camber of rear springs - by dickie65 - 09-07-2018, 09:04 PM
RE: Reducing camber of rear springs - by Jamie - 09-07-2018, 10:55 PM
RE: Reducing camber of rear springs - by Tom Coates - 11-07-2018, 11:12 AM
