U joint woes
Hi Erich
When this has been discussed before, someone said that there is a right way and a wrong way to put the circlips in.
Apparently, they have, or may have, one square edge and one chamfered edge and if inserted square edge up, don't seat properly.
One of mine didn't, I assumed I hadn't pushed the bearing in far enough, so hit it a bit harder.
I don't think it seated, I left it, to come back to it later, which I haven't yet done.
I am sure someone else will confirm if this is correct, or not.
Simon
U joint woes - by Erich - 03-07-2018, 02:32 AM
RE: U joint woes - by bob46320 - 03-07-2018, 06:28 AM
RE: U joint woes - by Dave Wortley - 03-07-2018, 07:26 AM
RE: U joint woes - by Chris KC - 03-07-2018, 07:49 AM
RE: U joint woes - by Jeff Taylor - 03-07-2018, 12:30 PM
RE: U joint woes - by Chris KC - 03-07-2018, 01:21 PM
RE: U joint woes - by Jeff Taylor - 04-07-2018, 02:06 AM
RE: U joint woes - by Erich - 04-07-2018, 03:48 AM
RE: U joint woes - by "Slack Alice" Simon - 04-07-2018, 09:16 PM
RE: U joint woes - by Chris KC - 05-07-2018, 07:52 AM
RE: U joint woes - by Erich - 06-07-2018, 05:10 AM
RE: U joint woes - by Tony Press - 06-07-2018, 05:59 AM
RE: U joint woes - by "Slack Alice" Simon - 06-07-2018, 07:54 AM
RE: U joint woes - by Erich - 06-07-2018, 08:46 PM
RE: U joint woes - by Phil Kingdom - 06-07-2018, 09:09 PM
