Sports bodies for a special or replica or travesty (depending on your point of view)
#39
I moved my steering box back a few inches, because I had no other choice, the box is mounted on a wedge to lower the angle of the column and as a result the brake rod has to be altered and the drag link extended by turning down a length of solid bar to the correct diameter with the ends slightly smaller to fit inside the tube an inch into the tube, then welding and adding a pin at each end of the joint.
RE: Sports bodies for a special or replica or travesty (depending on your point of view) - by Phil Kingdom - 29-06-2018, 12:46 PM
