Ruby rear screen drain channel
My 1937 Ruby has the rear window drain channels fitted and intact but there are no connected drain tubes. Connecting the drain tubes is obviously a straightforward task.... But where do the tubes exit the rear quarter panel. I am assuming through the bottom of the panel or even the B post, but if this is the case my car appears to have no hole. Can anyone appraise me of where it should exit?
Thank you
Ian
Ours exits between the structural part of the B-post and the rear wheelarch.
