Ruby rear screen drain channel - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Ruby rear screen drain channel (/showthread.php?tid=8893) |
Ruby rear screen drain channel - Ilmoro - 22-09-2023 My 1937 Ruby has the rear window drain channels fitted and intact but there are no connected drain tubes. Connecting the drain tubes is obviously a straightforward task.... But where do the tubes exit the rear quarter panel. I am assuming through the bottom of the panel or even the B post, but if this is the case my car appears to have no hole. Can anyone appraise me of where it should exit? Thank you Ian RE: Ruby rear screen drain channel - Peter Naulls - 22-09-2023 Ours exits between the structural part of the B-post and the rear wheelarch. |
