Dizzy screw
Don't ask me, I'm French. Je ne sais rien sur les filetages de vis et de boulons, même pas deux fois.
(17-04-2023, 07:10 PM)Reckless Rat Wrote: Don't ask me, I'm French. Je ne sais rien sur les filetages de vis et de boulons, même pas deux fois.
Une vis de reglage a un filetage sur toute de sa longuer, Un boulon a un filetage seulement a  l'extremite inferieure.
(PS. My keyboard doesn't do accents, a grave shortcoming of which I am acutely aware Big Grin )
A set screw with a little bit of thin tube?
A complexely thread is used on the Cemetary Mixer for sale on Farcebook
The stepped bolt on my car keeps unscrewing itself, but luckily the bottom of the distributor body stops it coming up so far that it falls out. If I try to tighten it up then the distributor adjustment locks up. Should there be a washer or spring under the head of the bolt?
David,
I have both and it works for me.
Hi David
I think there should be a spring under the head.
Thanks - I'll have another look at it tomorrow.
