Does anyone have or can spare the screw that goes from the dynamo into the distributor to stop it lifting. (Half thread half plain)
Or what size is the thread and would a completely threaded one suffice ?
Thanks all
A complexly threaded bolt will do the job.
Original thread 6mm may have been tapped out to 1/4bsf you need the plain end to engage the slot in the distributor. Terry.
David, what's a complexly bolt ?
I think he meant to say completely threaded bolt.
That could be an item for pedant's corner. The difference between a bolt and a set screw...
OK, Bruce. A completely threaded setscrew if you must, or is that tautologous?
