17-04-2023, 07:10 PM
(This post was last modified: 17-04-2023, 07:11 PM by Reckless Rat.)
Don't ask me, I'm French. Je ne sais rien sur les filetages de vis et de boulons, même pas deux fois.
Dizzy screw
17-04-2023, 09:55 PM
(This post was last modified: 17-04-2023, 10:19 PM by David Stepney.)
(17-04-2023, 07:10 PM)Reckless Rat Wrote: Don't ask me, I'm French. Je ne sais rien sur les filetages de vis et de boulons, même pas deux fois. Une vis de reglage a un filetage sur toute de sa longuer, Un boulon a un filetage seulement a l'extremite inferieure. (PS. My keyboard doesn't do accents, a grave shortcoming of which I am acutely aware )
17-04-2023, 11:11 PM
A set screw with a little bit of thin tube?
18-04-2023, 12:40 AM
A complexely thread is used on the Cemetary Mixer for sale on Farcebook
18-04-2023, 09:36 PM
The stepped bolt on my car keeps unscrewing itself, but luckily the bottom of the distributor body stops it coming up so far that it falls out. If I try to tighten it up then the distributor adjustment locks up. Should there be a washer or spring under the head of the bolt?
18-04-2023, 09:41 PM
David,
I have both and it works for me.
18-04-2023, 09:50 PM
Hi David
I think there should be a spring under the head. Cheers Howard
18-04-2023, 09:58 PM
Thanks - I'll have another look at it tomorrow.
