Austin Sports Models
A restored "Motor" cover:
.jpg   A7 Sports.jpg (Size: 516.75 KB / Downloads: 395)
Delightful! Is that what they call a Kempton?
More or less! It was called the Greyhound in 1934, renamed Kempton for 1935.
.jpg   1934 Greyhound.jpg (Size: 29.72 KB / Downloads: 327)
.jpg   1935 10.35 p1.jpg (Size: 124.4 KB / Downloads: 326)
I like that, a lot!
A wheel at each corner always look well.
I had decided that I had enough cars, only last week…
The correct number of cars is always determined by the formula N + 1 where N = the current number of cars owned...
I knew I liked you, Hugh…
I think you will find the name change became necessary following objections by AC Cars who were already using the name Greyhound.
There are only a handful of them left but I suspect the total production numbers were pretty low anyway.
I've always liked the Ten Ripley too. Similarly elegant. Strange that the grasshopper style grille appeared on so few cars; in every other respect Austins always seemed so strict about having the same "look" throughout the range.
.jpg   1934-Austin-10-Ripley-Sports-Tourer-Registration-Number_1636758856_9686.jpg (Size: 68.92 KB / Downloads: 204)
