Austin Sports Models - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Austin Sports Models (/showthread.php?tid=8024) Pages:
1
2
Austin Sports Models - Tony Griffiths - 11-09-2022 A restored "Motor" cover: ![]() RE: Austin Sports Models - Peter Naulls - 11-09-2022 Delightful! Is that what they call a Kempton? RE: Austin Sports Models - Mike Costigan - 11-09-2022 More or less! It was called the Greyhound in 1934, renamed Kempton for 1935. ![]() ![]() RE: Austin Sports Models - Ruairidh Dunford - 11-09-2022 I like that, a lot! RE: Austin Sports Models - Tony Griffiths - 11-09-2022 A wheel at each corner always look well. RE: Austin Sports Models - Ruairidh Dunford - 11-09-2022 I had decided that I had enough cars, only last week… RE: Austin Sports Models - Hugh Barnes - 11-09-2022 The correct number of cars is always determined by the formula N + 1 where N = the current number of cars owned... RE: Austin Sports Models - Ruairidh Dunford - 11-09-2022 I knew I liked you, Hugh… RE: Austin Sports Models - kenkimber - 12-09-2022 I think you will find the name change became necessary following objections by AC Cars who were already using the name Greyhound. There are only a handful of them left but I suspect the total production numbers were pretty low anyway. RE: Austin Sports Models - Peter Naulls - 12-09-2022 I've always liked the Ten Ripley too. Similarly elegant. Strange that the grasshopper style grille appeared on so few cars; in every other respect Austins always seemed so strict about having the same "look" throughout the range. |
