19-03-2022, 05:35 AM
I am rebuilding my speedometer on my car and was wondering is the speed in mph or kph or neither.
speedometer speed
19-03-2022, 08:53 AM
19-03-2022, 08:54 AM
For a ‘29 chummy the original speedo is a Smiths PA in mph.
19-03-2022, 09:40 AM
Hi All
Some export cars had a kph speedo. At least my 1930 RK had when it was exported. Cheers Howard ![]()
19-03-2022, 08:30 PM
I recall as a small boy playmates being very impressed by the 80 mph speedo on my Dads RP!
Incidentally the speedo later proved conservative, reading lower than various "moderns" compared with, so I suspect the top speed on true level no wind of 50 mph was accurate. On a regular 60 mile trip I used to acheive point to point times favourably comparable with my father in his 1952 Hillman but keeping to 50 mph indicated.
20-03-2022, 12:44 PM
My RP regularly clocks 85mph. This must be under-reading quite badly, as the 140,000 mile run into Hereford only takes about seven minutes, so I must actually be doing more that 1,200,000 mph.
20-03-2022, 02:43 PM
(20-03-2022, 12:44 PM)Martin Prior Wrote: My RP regularly clocks 85mph. This must be under-reading quite badly, as the 140,000 mile run into Hereford only takes about seven minutes, so I must actually be doing more that 1,200,000 mph. Or about 1/60th of the speed of light! Mind you, speedometer readings are all purely relative anyway. ![]() Where's my coat........?
20-03-2022, 05:14 PM
My Magmo speedometer gently swings between 35 and 45 mph most of the time but it feels close to the speed of light sometimes...
