14-01-2022, 09:33 PM
Do I need a resistor in series to run a 6V Rist horn on 12 Volts? If so can anyone recommend an Ohm value and even a specific item?
Rist Horn on 12 Volts
14-01-2022, 10:01 PM
(This post was last modified: 14-01-2022, 10:01 PM by Peter Clayton.)
I run my six volt klaxon on twelve volts. works well and scares the bejesus out of those who offend me.
15-01-2022, 09:02 AM
My 6v Rist horn has been on 12v for the last 18 years.
16-01-2022, 10:44 PM
Thank you both that is re-assuring so I need to do nothing and that is a change!
17-01-2022, 10:12 AM
Can I ask a question just out of curiosity. Does running a 6 volt horn on 12 volts change the tone or its volume.
John Mason.
17-01-2022, 04:13 PM
Will raise tone/pitch and volume. Possibly eyebrows as well.
17-01-2022, 06:39 PM
Whilst the Benjamin horn sounds OK on 12 volts the Rist horn was a bit too shrill for a Seven so I used a spare dynamo field resistor to drop the voltage to give a more acceptable tone.
