Modification to uncoupled brakes
I came across this the other day. Good thing to do, or not?
.png   image_2021-08-25_102110.png (Size: 131.68 KB / Downloads: 664)
Yes a good thing to do
I have done this many times and agree with Alan, a good and sensible modification to make.
During the Top Hat chassis restoration, I welded straps from the top of the cross shaft bracket to the front crossmember. Has to be done in the dismantled state to avoid melting the zinc bushes. I can report that the brake pedal is firm and the brakes work remarkably well. I also re-fabricated the "Bodello" coupling device......
Hi Nick
Yes definitely.  I used pipe brackets with a copper “bearing” soldered in. (Excuse the Phillips head set screws  Blush ).
I don't understand the need for the "bearing" Howard. Only for not allowing the bolt to rub directly on the shaft?
I think it is just used to reduce the internal diameter of the pipe clamp for a good fit Renault...but I could be wrong!
(25-08-2021, 11:57 AM)Ivor Hawkins Wrote: I think it is just used to reduce the internal diameter of the pipe clamp for a good fit Renault...but I could be wrong!
Spot on Ivor  Big Grin.
A similar one at the near side would prevent the bracket moving back.
watching underneath while someone presses the brake pedal is interesting. The movement on the brackets is surprising!
(25-08-2021, 05:14 PM)AustinWood Wrote: A similar one at the near side would prevent the bracket moving back.
I have exactly that arrangement  Smile.
.jpeg   3EA322B0-A79C-4944-88FB-5520A9D7A152.jpeg (Size: 117.72 KB / Downloads: 343)
