Ruby track rod bush
Hi I need to remove the bronze bushing from the track rod arms.  Is it something I can press out or do I need to go to an engineering works to also press new ones in? Smile
I think they will come out using a suitable size plain punch. Fitting the new ones can be achieved by squeezing in a vice, after which they need careful reaming to size.
The worn ones can be easily removed by CAREFULLY cutting through the bushes with a junior hacksaw which makes it simple to drift them out. New ones pushed in using Vice as already suggested.
Thanks guys you for your advice will do as suggested Smile
