Ruby track rod bush - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Ruby track rod bush (/showthread.php?tid=6420) |
Ruby track rod bush - andrew767767 - 25-07-2021 Hi I need to remove the bronze bushing from the track rod arms. Is it something I can press out or do I need to go to an engineering works to also press new ones in? ![]() RE: Ruby track rod bush - Robert Leigh - 25-07-2021 I think they will come out using a suitable size plain punch. Fitting the new ones can be achieved by squeezing in a vice, after which they need careful reaming to size. RE: Ruby track rod bush - Charles Levien - 25-07-2021 The worn ones can be easily removed by CAREFULLY cutting through the bushes with a junior hacksaw which makes it simple to drift them out. New ones pushed in using Vice as already suggested. RE: Ruby track rod bush - andrew767767 - 27-07-2021 Thanks guys you for your advice will do as suggested ![]() |
