Does anyone have a good source of (quality) fibre washers? I bought a selection box through Ebay some while back as they were marked as being imperial sizes. However, the range is poor (there are many of the sizes that are simply a thin 'ring' and don't work well for drain plugs etc.) But their worst fault is they are rock hard and I fear don't behave as originals would have done.
Any ideas anyone?
tia
Hugh
That's very generous Colin, and much apreciated. Let me determine exactly the size I want (rear axle drain plug is my current concern) and I'll drop you a PM...
thanks once again..
25-07-2021, 06:48 PM
(This post was last modified: 25-07-2021, 06:49 PM by Chris KC.)
"Hoses Direct" sell fibre washers in imperial sizes, when I see you Hugh I can probably produce a sample or two (I need to remind myself whether they are narrow or not).
You wouldn't want to order just one though, I order a few when I'm buying something else. (If stuck for something specific, give me a shout).
I usually boil them in water for a minute or two before using them, softens them up a bit.
